AFF
Hybrid flash in fas
fwilliam
I need to find out more details of how cDOT reacts to a node that has a flash aggregate and a sas disk aggregate. Any pointers appreciated. Thanks.
Bill
1 REPLY 1
jodey
cDOT reacts no differently to either node. All of the standard rules apply -- an aggregate with a Flash Pool will not have access to Flash Cache -- you can have an all SSD aggregate coexist with a HDD aggregate on the same node -- you can have an all flash node and then an HDD/hybrid node.
What exactly are you looking for?
J
