DFM/PM 4.0.2 fails to provision secondary volume on FAS6280 64bit aggr with dedupe enabled
mark_schuren
Hi community (and devs),
I have a problem at a customer with a provisioning policy in PM.
It is a provisioning policy for snapvault secondary volumes. PM should provision the SV destination volumes automatically (with dedupe enabled on the destination).
The destination filer is a FAS6280 - running 8.0.2, and the destination ressource pool is a 64bit aggregate.
The problem happens when deduplication is enabled in the policy for the secondary volumes. If Dedupe is enabled, PM errors with "the destination's dedupe limit is 512GB", and fails to provision new secondary volumes (which need to be larger that 512GB).
AFAICT a 6280 should not have a 512GB limit for deduplicated volumes, right? 😉
DFM Version 4.0.2D2 - ONTAP 8.0.2 DFM plugins are installed (though DFM was not restarted yet after installing the plugin) - 64bit aggregate on the secondary.
We also have a FAS3160 as another secondary, here the same policy works fine (and provisions secondary volumes >2 TB without that error). On the 6280 it only works without dedupe enabled in the policy...
Can anyone reproduce this? New Bug? Workaround?
Thanks for any hints,
Mark
1 ACCEPTED SOLUTION
sinhaa
Hello Mark,
This is one very common problem that is being reported to us. The thing is DFM 4.0.2D2 doesn't recognize FAS6280 as a valid filer model and hence defaults to 512 MB. This support should be available with the OnCommand version 5.0 which is going to be available very soon.
You are right the Dudupe limit for 6280 with 8.0.2 is 16TB and not 512 GB.
The concerned burt is 508580:
In the mean time you can follow the following steps and it should go ahead fine:
1. Set the deduplication limit for FAS380 with ONTAP 8.0.2 in the following way.
$dfpm reslimit create "8.0.2" "FAS3280"
Created new resource limit (215).
2. Set Maximum deduplication size of FAS3280 and ONTAP version 8.0.2 (in GB)
$dfpm reslimit set 215 maxDedupeSizeInGB=16384
3. Verify the deduplication limit set for FAS3280 with ONTAP 8.0.2
$dfpm reslimit get 215
Id        215
ONTAP Version        8.0.2
Product Model        FAS3280
Availability        None
Maximum number of FlexVols per storage controller
Maximum CPU utilization threshold of storage controller
Maximum Disk utilization threshold of an aggregate
Maximum Deduplication size of a storage system model and ONTAP version (in GB) 16384
4. Done. You are ready to go.
warm regards,
Abhishek
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
4 REPLIES 4
sinhaa
Hello Mark,
Id        215
ONTAP Version        8.0.2
Availability        None
warm regards,
Abhishek
mark_schuren
Hello Sinhaa,
thank you very much fort he detailed and quick reply!
Will try that with customer as soon as possible. I think your meant „FAS6280“, not „FAS3280“, right?
Thanks again,
Mark
Von: sinhaa
Gesendet: Dienstag, 2. August 2011 09:15
An: Mark Schuren
Betreff: "DFM/PM 4.0.2 fails to provision secondary volume on FAS6280 64bit aggr with dedupe enabled"
<http://communities.netapp.com/index.jspa>
Re: DFM/PM 4.0.2 fails to provision secondary volume on FAS6280 64bit aggr with dedupe enabled
created by sinhaa<http://communities.netapp.com/people/sinhaa> in OnCommand Mgmt Software - View the full discussion<http://communities.netapp.com/message/60055#60055>
Hello Mark,
You are right the Dudupe limit for 6280 with 6.0.2 is 16TB and not 512 GB.
Id 215
ONTAP Version 8.0.2
Availability None
warm regards,
Abhishek
  1. of replies to the post:
Discussion thread has 1 replies. Click here<http://communities.netapp.com/message/60055#60055> to read all the replies.
Original Post:
Hi community (and devs), I have a problem at a customer with a provisioning policy in PM. It is a provisioning policy for snapvault secondary volumes. PM should provision the SV destination volumes automatically (with dedupe enabled on the destination). The destination filer is a FAS6280 - running 8.0.2, and the destination ressource pool is a 64bit aggregate. The problem happens when deduplication is enabled in the policy for the secondary volumes. If Dedupe is enabled, PM errors with "the destination's dedupe limit is 512GB", and fails to provision new secondary volumes (which need to be larger that 512GB). AFAICT a 6280 should not have a 512GB limit for deduplicated volumes, right? DFM Version 4.0.2D2 - ONTAP 8.0.2 DFM plugins are installed (though DFM was not restarted yet after installing the plugin) - 64bit aggregate on the secondary. We also have a FAS3160 as another secondary, here the same policy works fine (and provisions secondary volumes >2 TB without that error). On the 6280 it only works without dedupe enabled in the policy... Can anyone reproduce this? New Bug? Workaround? Thanks for any hints, Mark
Reply to this message by replying to this email -or- go to the message on NetApp Community<http://communities.netapp.com/message/60055#60055>
Start a new discussion in OnCommand Mgmt Software by email<mailto:message-community-products_and_solutions-storage_management_software@netapp-community.hosted.jivesoftware.com> or at NetApp Community<http://communities.netapp.com/choose-container!input.jspa?contentType=1&containerType=14&container=2026>
Stay Connected:
<http://www.facebook.com/NetApp>
Facebook<http://www.facebook.com/NetApp>
<http://twitter.com/NetApp>
Twitter<http://twitter.com/NetAppCommunity>
<http://www.linkedin.com/groups?about=&gid=111681>
LinkedIn<http://www.linkedin.com/groups?about=&gid=111681>
<http://www.youtube.com/user/NetAppTV>
YouTube<http://www.youtube.com/user/NetAppTV>
Community<http://communities.netapp.com/index.jspa>
© 2011 NetApp<http://www.netapp.com/us/site/copyright.html> | Privacy Policy<http://www.netapp.com/us/site/privacy.html> | Unsubscribe<http://communities.netapp.com/user-notification-preferences!input.jspa> | Contact Us<mailto:xdl-communities@netapp.com>
495 E. Java Drive, Sunnyvale, CA 94089 USA
sinhaa
Yes Mark. Its FAS6280. FAS3280 is also another model new model which is also faces similar problems.
1. Set the deduplication limit for FAS6280 with ONTAP 8.0.2 in the following way.
$dfpm reslimit create "8.0.2" "FAS6280"
2. Set Maximum deduplication size of FAS6280 and ONTAP version 8.0.2 (in GB)
3. Verify the deduplication limit set for FAS6280 with ONTAP 8.0.2
Id        215
ONTAP Version        8.0.2
Product Model        FAS6280
Availability        None
mark_schuren
Thank you very much again!
Regards,
Mark
Von: sinhaa
Gesendet: Tuesday, August 02, 2011 10:01 AM
An: Mark Schuren
created by sinhaa<http://communities.netapp.com/people/sinhaa> in OnCommand Mgmt Software - View the full discussion<http://communities.netapp.com/message/60057#60057>
Id 215
ONTAP Version 8.0.2
Availability None
Discussion thread has 3 replies. Click here<http://communities.netapp.com/message/60057#60057> to read all the replies.
Original Post:
Reply to this message by replying to this email -or- go to the message on NetApp Community<http://communities.netapp.com/message/60057#60057>
Stay Connected: <http://www.facebook.com/NetApp> Facebook<http://www.facebook.com/NetApp> <http://twitter.com/NetApp> Twitter<http://twitter.com/NetAppCommunity> <http://www.linkedin.com/groups?about=&gid=111681> LinkedIn<http://www.linkedin.com/groups?about=&gid=111681> <http://www.youtube.com/user/NetAppTV> YouTube<http://www.youtube.com/user/NetAppTV> <http://communities.netapp.com/index.jspa> Community<http://communities.netapp.com/index.jspa>
