WFA 7m Create Primary Volume Primary Qtree --> Create Secondary Volume --> Create Vault
lagenevoise
Dear Comunity Members,
I would like create un SnapVault Relationship with WFA.
I don't want create a complex SnapVault with retry and schedule just like CLI
Snapvault start
regards.
1 REPLY 1
Adai
Hi,
      What are you looking for ? A Sample workflow for 7Mode snapvault or so ? I just checked and did not find one both in WFA 3.0 and 2.2.
But there are certified commands, for snapvualt, that should help you with setting up snapvault workflows.
BTW if you are just looking for simple snapvault automation, you should try the protection manager or backup manger or OnCommand System Manager which does automate the setup of snapvault relationship in 7mode.
Regards
adai
