Data Backup and Recovery
Problems with SMSQL Cloning to remote Host --> 0x80070005 Access is denied
it_1
Hello @all,
i'm a little bit confused about the following error message in my environment.
1) 2 VMs (svtidbv057, svtidbv058)
2) Both running W2k8 R2 with SnapDrive 6.2 & SMSQL 5.0
3) Running configuration with Snapshots and Verification are working fine
4) local snapdrive User for SnapDrive and Mngmt with local administrator privileges
5) SnapManager Service running in a Active Directory User with local administrator privileges
So ....
We want now to clone a database from VM57 to VM58 by using a recently taken backup.
The task starts and all seems to fine unless ....
[23:41:15.231]  Connecting to SQL Server [svtidbv058] for restore SQL Server version checking...
[23:41:15.245]  Mounting SnapInfo Drive...
[23:41:15.247]  Mounting Snapshot [sqlinfo__svtidbv057__recent] for LUN E of Computer SVTIDBV057
[23:41:15.249]  SnapManager will use directory C:\Program Files\NetApp\SnapManager for SQL Server\SnapMgrMountPoint to mount snapshot sqlinfo__svtidbv057__recent.
[23:41:15.251]  Mount point directory [C:\Program Files\NetApp\SnapManager for SQL Server\SnapMgrMountPoint]
[23:41:15.257]  Snapshot will be mounted on subdirectory [MPDisk001]
[23:41:15.275]  [SnapDrive Error]: Access is denied.
(SnapDrive Error Code: 0x80070005)
[23:41:15.277]  Unable to mount the snapinfo directory snapshot
[23:41:15.279]
[23:41:15.281]  *** SNAPMANAGER MOUNT BY RESTORE (CLONE) JOB ENDED AT: [02-08-2011 23.41.57]
[23:41:15.282]  Error Code: 0x80070005
Access is denied.
BUT!...
If i try to connect the snapshot via Snapdrive (Connect Disk on remote host svtidbv058) the mounting process starts and ends successfully.
I can access the recently connected disk.
There are some events shown on the remote system svtidbv058 (where the clone should be go online)
1) SnapDrive
Failed to connect the LUN in Snapshot copy (sqlinfo__svtidbv057__recent) as drive on the computer (SVTIDBV058).
LUN Name = Not available
Storage Path = Not available
Protocol Type = LUN
Storage System Name =
Error code : Access is denied.
Contains no LUN Name!
But Storage is connected an can see all luns with snapshots. (manually connect is working!)
2) SnapManager for SQL
SnapManager for SQL Server database restore to alternate location, using a writable LUN that is backed by a snapshot, failed.
Access is denied
Seems to be an error in the SnapDrive Communication.
But what can i do now?
Thanks for your help
BR Stefan
14 REPLIES 14
