ONTAP Discussions
7MTT Cifs timeout issue
michaelll
I have a basic network setup in the lab, just a single subnet.  I'm working on testing a full cifs migration and keep running into this error.  I have deleted the few local accounts that were in place because I don't need them.
Applying the CIFS local users and groups information from the 7-Mode storage system '192.168.1.130' to the SVM 'shares'.Failed to apply the CIFS local users and groups information from the 7-Mode storage system '192.168.1.130' to the SVM 'shares'. Error Code: 343 Reason: Network error occurred: Timeout was reached : connect() timed out!.
This is all the console of the source filer says:
Tue Sep 16 11:39:26 EST [ntap2040:app.log.info:info]: veeam2008: 7-Mode Transition Tool 1.3.0: (5001) CBT:standalone:precutover: Session:cifsserver_standalone:c4db0899-1b3d-4aca-a4fe-1f55f5fc395a;T=01:13;M:2;E:1;W:5;EC:20933;WC:20254,20305,90701,40111,20274;
Tue Sep 16 11:39:26 EST [ntap2040:app.log.info:info]: veeam2008: 7-Mode Transition Tool 1.3.0: (5002) CBT:standalone:precutover: cifsserver_standalone:c4db0899-1b3d-4aca-a4fe-1f55f5fc395a;7M:0135110197:vfiler0;CM:805689c1-216e-11e4-9725-123478563412:shares;
and the 7MTT logs:
2014-09-16 11:37:23.778 EDT [c.n.t.jobmanager.AbstractJob: INFO] [job-mngr-3] [operation-name: precutover]: 20172:No CIFS preferred Domain-Controller configuration found on the 7-Mode storage system '192.168.1.130'.
2014-09-16 11:37:23.880 EDT [c.n.t.o.collect.CifsCollectHandler: INFO] [job-mngr-3] [operation-name: precutover]: No symlink configuration found on the 7-Mode storage system
2014-09-16 11:37:24.092 EDT [c.n.t.f.p.s.CifsShareAclsParser: INFO] [job-mngr-3] [operation-name: precutover]: Found comment line in /etc/cifsconfig_share.cfg
2014-09-16 11:37:24.208 EDT [c.n.t.jobmanager.AbstractJob: INFO] [job-mngr-3] [operation-name: precutover]: 70161:Successfully translated Snapshot copy schedule information of the 7-Mode volumes to the clustered Data ONTAP volumes.
2014-09-16 11:37:24.208 EDT [c.n.t.jobmanager.AbstractJob: INFO] [job-mngr-3] [operation-name: precutover]: 70171:Successfully translated space reservation information of the 7-Mode volumes to the clustered Data ONTAP volumes.
2014-09-16 11:37:24.221 EDT [c.n.t.o.t.CifsTranslateHandler: INFO] [job-mngr-3] [operation-name: precutover]: No prefdc configured collected
2014-09-16 11:37:24.221 EDT [c.n.t.o.t.CifsTranslateHandler: DEBUG] [job-mngr-3] [operation-name: precutover]: nothing to translate as we don't have any usermap entries collected.
2014-09-16 11:37:24.221 EDT [c.n.t.jobmanager.AbstractJob: INFO] [job-mngr-3] [operation-name: precutover]: 20191:Successfully translated the 7-Mode 'CIFS user-mapping' configuration to the cluster.
2014-09-16 11:37:24.221 EDT [c.n.t.o.t.CifsTranslateHandler: DEBUG] [job-mngr-3] [operation-name: precutover]: No symlink entries collected to translate.
2014-09-16 11:37:24.221 EDT [c.n.t.jobmanager.AbstractJob: INFO] [job-mngr-3] [operation-name: precutover]: 20201:Successfully translated the 7-Mode option 'cifs.smb2.enable' to the cluster.
2014-09-16 11:37:24.222 EDT [c.n.t.o.t.CifsTranslateHandler: DEBUG] [job-mngr-3] [operation-name: precutover]: No CIFS winservers are collected to translate.
2014-09-16 11:37:24.222 EDT [c.n.t.jobmanager.AbstractJob: INFO] [job-mngr-3] [operation-name: precutover]: 20191:Successfully translated the 7-Mode 'CIFS shares' configuration to the cluster.
2014-09-16 11:37:24.222 EDT [c.n.t.jobmanager.AbstractJob: INFO] [job-mngr-3] [operation-name: precutover]: 20311:Successfully translated CIFS share-level ACLs from the 7-Mode storage system to the SVM.
2014-09-16 11:37:24.222 EDT [c.n.t.o.t.CifsTranslateHandler: DEBUG] [job-mngr-3] [operation-name: precutover]: No home-directory paths collected to translate.
2014-09-16 11:37:25.603 EDT [c.n.t.jobmanager.AbstractJob: INFO] [job-mngr-3] [operation-name: precutover]: 10094:The root volume of the SVM 'shares' is exported with export policy 'transition_readonly' which allows read-only access for all the NFS clients.
2014-09-16 11:38:31.199 EDT [c.n.t.o.apply.WaflApplyHandler: DEBUG] [job-mngr-3] [operation-name: precutover]: CronJob policy does not exists with name CronJob_shares_cluster1_8
2014-09-16 11:38:31.256 EDT [c.n.t.o.apply.WaflApplyHandler: DEBUG] [job-mngr-3] [operation-name: precutover]: CronJob policy does not exists with name CronJob_shares_cluster1_9
2014-09-16 11:38:31.469 EDT [c.n.t.o.apply.WaflApplyHandler: DEBUG] [job-mngr-3] [operation-name: precutover]: SnapShot policy does not exists with name SnapShot_shares_cluster1_4
2014-09-16 11:38:32.338 EDT [c.n.t.session.util.TransitionLocks: DEBUG] [job-mngr-3] [operation-name: precutover]: Session 'cifsserver_standalone' released the lock with thread id '39', job '4b59431b-50e4-47e7-9083-119a37c8ca5c' and cluster uuid of '805689c1-216e-11e4-9725-123478563412' from thread '1179'.
2014-09-16 11:38:32.338 EDT [c.n.t.session.util.TransitionLocks: DEBUG] [job-mngr-3] [operation-name: precutover]: Session 'cifsserver_standalone' released the lock with thread id '39', job '4b59431b-50e4-47e7-9083-119a37c8ca5c' and filer uuid of '0135110197'.
The ZAPI log looks to be sending and receiving fine as well.
This is at the Pre-cutover section, and I cannot proceed past it.
1 ACCEPTED SOLUTION
DOMINIC_WYSS
as of KB 2019744:
Cause
The Windows firewall is blocking access to port 8088 on the workstations on which 7MTT is running.
https://kb.netapp.com/support/index?page=content&id=2019744&locale=en_US
3 REPLIES 3
DOMINIC_WYSS
as of KB 2019744:
Cause
Anand_1986
Just go to job show on cluster and delete the particuler running ID the it works
Chris_
worked for me. Thanks!
