ONTAP Discussions
FAS3220 Dual Chassis HA interconnect error
uwf_chowell
Have a 2-node FAS2554 running ONTAP 9. I see this error message in the event log a couple of times an hour from both nodes:
csm.sessionFailed: Cluster interconnect session (req=uwfclu1c-01:dblade, rsp=uwfclu1c-02:dblade, uniquifier=08053e1f8099756e) failed with record state ACTIVE and error CSM_CONNABORTED
The error message appears to be benign so I'm just wondering where this is coming from.
Thanks,
--Carl
3 REPLIES 3
aborzenkov
I do not know exact reason for this message, but it is not HA, it is cluster interconnect.
sam_wozniak
I'm seeing this too on a FAS3220 recently upgraded to 8.3.2P5 and separately on a FAS2650 running 9.1RC1.
Emile-Bodin
Hello,
The CSM (cluster session manager) is responsible for the connections between de dblades on the local or remote node/cluster.
The error "failed with record state ACTIVE and error CSM_CONNABORTED" is a message that is logged whenever a active snapmirror session has been completed and the connection is closed. In most cases this message is informational.
If you are experiencing snapmirror or cluster peering issues I would recommend opening a support case for further investigations.
Regards
