ONTAP Discussions
Throughput counters for FC and SAS ports on a controller?
gpnetsupport
Maybe a silly question...
It's very easy - coming from a Cisco shop - to grab throughput and data statistics for things like physical ports or vlan interfaces on a cisco switch or router.  Is there an equivalent command to issue on a filer to get the same kind of data for an actual FC or SAS uplink on a head?
Just trying to gauge where I'm at with uplink utilization (whether or not I'm bottlenecking with too many shelves in a loop, etc).  Thanks in advance.
1 REPLY 1
pascalduk
In advanced mode the stats counter hostadapter is available which shows FC and SAS port statistics. E.g.:
*> stats show -c hostadapter
Instance total_reads total_writes bytes_read bytes_writte max_link_dat
                  /s           /s         /s           /s         KB/s
      3a          63           79     645998      1023992       250000
      3b           3           12      18589       274200       250000
      3c         597           93    3922462      4217835       250000
      3d           0           13       4647       339265       250000
      0c          57           80     604170       924846       250000
      0d         642           57    3671499      2100655       250000
      0a        1367          101    9885163      6685640      1500000
      0b        3188           78   20355908      8988202      1500000
