ONTAP Discussions
upgrade 32bit aggr to 64bit
TDUBB1234
how do I upgrade a 32bit aggr to 64 bit? what are the steps and downtime?
21 REPLIES 21
scottgelb
With ONTAP 8.1, you add disks to grow the aggregate over 16TB and it will automatically convert in the background (no downtime) from 32 to 64 bit.  Growing over 16TB is the only supported method.  If you search this community you will see some posts of a diag mode in place method without adding disks but that is not supported (diag mode command).
You can also replicate from 32 to 64 with ONTAP 8.1 and have a quick downtime while you cutover to the new volume but if you are on 8.1 then the best solution is to add disks and convert the existing aggr for now downtime.
aborzenkov
It does not do this automatically, you have to explicitly say you want to convert when adding disks. Otherwise it just rejects command if size will exceed 16TiB.
scottgelb
System manager should give a popup they can click wen growing to convert. Do you use cli or system manager and is it ontap 8.1?
aborzenkov
CLI of course ☺
TDUBB1234
but im on  8.0.1P3. how do i convert to 64bit without upgrading to 8.1?
radek_kubka
Basically you can't.
What you can do, is to create new 64-bit aggregate and then migrate the data off the old one, e.g. via Qtree SnapMirror (VSM won't work unfortunately).
Regards,
Radek
scottgelb
Qtree snapmirror or Ndmpcopy if not on 8.1. It might be worth waiting for your upgrade. Then you can upgrade in place by growing the aggr or volume snapmirror too 32 to 64.
Sent from my iPhone 4S
radek_kubka
I see I need to add a signature to my posts: "Send from my (awesome) Android phone" 🙂
scottgelb
Reply to the email notification on a thread and it is from email
Re: upgrade 32bit aggr to 64bit
created by Radek Kubka in Data ONTAP - View the full discussion
Reply to this message by replying to this email -or- go to the message on NetApp Community
Start a new discussion in Data ONTAP by email or at NetApp Community
TDUBB1234
what is besrt way to move my vnmware luns off this 32bit aggr to 64bit? create new 64bit aggr/vol/qtree/lun and svmotion the vms off the old luns or can i still use qtree snapmirror?
scottgelb
Storage VMotion would be a great way to do this...then you don't have downtime.
TDUBB1234
how do i qtree snap mirror between 2 qtrees? i have 2 luns on 2 different aggr
scottgelb
QSM creates a qtree on the target volume for you.. So you can mirror any source qtree (or non qtree data by specifying /vol/volname/-  ... the dash meaning non-qtree data as the source) and the target is always a qtree.  You specify the source /vol/volname/qtree or "-" and the target /vol/volname/qtree.. the target volume can have multiple qtree mirrors if you want.
But if VMware and the goal is non-disruptive 32 to 64 bit (and not ontap 8.1) then storage vmotion sounds like a much better fit.
radek_kubka
Just bear in mind Storage VMotion is a host-side operation, so with large VMs may be problematic performance-wise.
fhauntsman
Hi, I just receive this document from support after searching and searching, great doc..
In-Place Expansion of 32-Bit Aggregates to 64-Bit
Overview and Best Practices
Link= http://media.netapp.com/documents/tr-3978.pdf
Enjoy and hope this helps
igalkatzir
Great Article indeed, the syntax from cli goes like this:
aggr add aggr_name -64bit-upgrade normal -n 2
This is when you want to add two disks to the aggr.
Igal
SHARMAMANISH
You Can do via a priv set diag command
aggr 64bit-upgrade start aggr1 -mode grow-all
aborzenkov
You should never use diag level command without explicit instructions from NetApp. Conversion to 64 bit (without adding disks and diag commands) is supported as of 8.2.1RC1.
scottgelb
Agree 100% with this. Not without support prior to 8.2.1. Unless a lab or test environment maybe. This was not supported until 8.2.1 even though hidden prior and carries risk without support.
Sent from my iPhone 5
oweinmann
Hi,
I have to migrate data using the 7Mode Transition tool to our new CDOT 8.3 Filer. Problem is that I can only use 7Mode transition tool if the source Volume is 64Bit. Unfortunately the volumes on our old 7Mode system are only 32Bit. The 7mode system (FAS 2040) is running the latest availabe ontap release:
NetApp Release 8.1.4P8 7-Mode
the CDOT is running 8.3RC1.
How can I convert the 32Bit Volumes to 64Bit? I did run:
aggr 64bit-upgrade start aggr0 -mode grow-all
on one of the old filers without a problem, but there was just one small volume and no production data on. I'm a bit afraid to run it on the production filer, but as far as I can see there is no way around it?
