ONTAP Hardware
ONTAP Hardware
I just got to a new customer and this is something I found early on... in short, clus1, clus3 and clus4 all show as being homed on e0a for the same node. I see this for other systems where clus1 and clus2 may be the only cluster ports (FAS62xx) and both show homed on e0c, for example.
Vserver Name | Cluster | Cluster | Cluster | Cluster |
Logical Interface Name | node1_clus1 | node1_clus2 | node1_clus3 | node1_clus4 |
Role | cluster | cluster | cluster | cluster |
Data Protocol | none | none | none | none |
Home Node | node1 | node1 | node1 | node1 |
Home Port | e0a | e0b | e0a | e0a |
Current Node | node1 | node1 | node1 | node1 |
Current Port | e0a | e0b | e0a | e0a |
Operational Status | up | up | up | up |
Numeric ID | 1024 | 1023 | 1035 | 1034 |
Is Home | TRUE | TRUE | TRUE | TRUE |
Network Address | 169.254.2.171 | 169.254.2.172 | 169.254.2.173 | 169.254.2.174 |
Netmask | 255.255.0.0 | 255.255.0.0 | 255.255.0.0 | 255.255.0.0 |
Administrative Status | up | up | up | up |
Any ideas as to why this might be?
Solved! See The Solution
I'm curious as to how the FAS62xx ended up with four cluster LIFs in the first place. Best practices only require 2 cluster ports and LIFs.
Regardless, if you really only have 2 cluster ports e0a and e0b, just delete the 2 extra LIFs. Make sure you end up with a cluster LIF home-ported on each port.
See: https://kb.netapp.com/support/s/article/ka31A0000004YpD/How-to-delete-a-Cluster-LIF
More info... from ASUP for node1, ifconfig -a section:
e0a: flags=0x1f0c867<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM,LRO,CLUSTER_PORT> mtu 9000
inet 169.254.2.171 netmask 0xffff0000 broadcast 169.254.255.255 noddns CLUSTER Vserver ID: -3
inet 169.254.2.173 netmask 0xffff0000 broadcast 169.254.255.255 noddns CLUSTER Vserver ID: -3
inet 169.254.2.174 netmask 0xffff0000 broadcast 169.254.255.255 noddns CLUSTER Vserver ID: -3
ether 00:a0:98:67:6a:65 (auto-10g_sr-fd-up) flowcontrol none
e0b: flags=0x1f0c867<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM,LRO,CLUSTER_PORT> mtu 9000
inet 169.254.2.172 netmask 0xffff0000 broadcast 169.254.255.255 noddns CLUSTER Vserver ID: -3
ether 00:a0:98:67:6a:66 (auto-10g_sr-fd-up) flowcontrol none
