FlexPod Discussions
Best Way to Cable from FAS6240 to UCS
CLOUDMINER
I need to cable from a FAS6240 to a UCS, so that I can present iSCSI LUNs.  Should I connect my 6240 directly to the UCS Fabric Interconnect?  The UCS Fabric Interconnect is also connected to Nexus 7000K switches.  I could connect the 6240 to the 7000K, and then iSCSI traffic would flow through the 7000K and from there to the Fabric Interconnect.  Which is the best option? There is no option to have a dedicated switch for iSCSI.
Thanks!
1 ACCEPTED SOLUTION
kathick
Hello,
Though direct connecting FAS to Fabric Interconnect is supported, I would recommed to connect your FAS6240 to Nexus7000 switch(since you already have Nexus 7K in place). Please have a look at the reference architecture which we did sometime back with Nexus 7K (iSCSI.
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/UCS_CVDs/flexpod_esxi_N7k.html
By connecting FAS to Nexus you can leverage vPC/LACP features for your iSCSI traffic and the loadbalancing is taken care automatically.
Hope this helps.
Thanks,
Karthick
4 REPLIES 4
kathick
Hello,
Hope this helps.
Thanks,
Karthick
CHRISMAKI
Is there a CVD that shows the NetApp connected directly to the FI?
kathick
Hello,
Yes, we do have CVD's which has the configuraiton details of connecting NetApp FAS to Cisco Fabric Interconnect.
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/UCS_CVDs/flexpod_esxi60u1_n9k.html#_Toc456185285
www.cisco.com/c/en/us/td/docs/unified_computing/ucs/UCS_CVDs/flexpod_express_ucsmini_esxi55_ip.html
Hope this helps.
Thanks,
Karthick
CLOUDMINER
Ok thanks
