Network and Storage Protocols
Deleating volume in Provisioning\Protection Manager
muhammad_i_pasha
Hi - I am trying to figure out how to restore a deleted volume in Provisioning manager. When you try to restore to its original location, PM fails as it tries to look for a deleted volume.
As a workaround I manually created a volume on the Filer with same name. Started a restore from PM.  Restore worked fine but PM doesn’t pick up manually created volume as a result any protection policies didn't work on manually created volume.
I then manually created a SM relationship for restored volume and import into DS.
Is this right method to restore volume and import into Dataset or is there another straight forward method?
4 REPLIES 4
muhammad_i_pasha
Problem with above procedure is when you create a manual SM relation it has to rebaseline.
adaikkap
Hi Muhammad,
                     I am not clear on the scenario.Let me see if I understood it correctly.
You have a dataset with Mirror policy.
As below.
C:\>dfpm dataset list -m 214
Id         Node Name            Dataset Id Dataset Name         Member Type                                        Name
       215 Primary data                  214 NfsOnly              volume                                             sim1:/SourceOnly
       220 Mirror                            214 NfsOnly              volume                                             sim2:/MirrorData
C:\>
Your primary is deleted, in the filer
Now you are trying to backup from Mirror node.
Is this correct ?
BTW what is the output of dfpm dataset list -m <dsid>  now when the primary is deleted.
Regards
adai
muhammad_i_pasha
Hi Adai, Thanks for a quick response.
Protection Policy is "Mirror then Backup". VSM source is deleted now I am trying to restore from a VSM destination using PM restore.
#dfpm dataset list
Id         Name                        Policy                      Provisioning Policy Storage Service
      1073 test_DS1                    VSM then SV                 test_policy1
muhammad_i_pasha
Adai, any thoughts on this?
