Network and Storage Protocols
Multistore max_mpx
sjallabais
Hi!
I am trying to understand how the max_mpx setting should be handled when having multiple vfilers.
In a Citrix environment this should be increased, but it looks like the "Max Multiplex" from the "cifs stat"
command are higher than the cifs.max_mpx setting.
Are this somehow shared between vfilers, or do each vfiler have their own separate mecanism for this?
I have seen recomendations to set it high initially (1124) when running Citrix, and others wants to fine
tune..
Has vfiler0 max_mpx setting any influence on the vfilers?'
/Sjalla
2 REPLIES 2
scottgelb
The max_mpx setting is set separately per vFiler.  The setting in vfiler0 does not affect non-default vfilers.
http://now.netapp.com/NOW/knowledge/docs/ontap/rel801/html/ontap/cmdref/man1/na_options.1.htm
cifs.max_mpx
This option controls how many simultaneous operations the filer reports that it can process. An "operation" is each I/O the client believes is pending on the filer including outstanding change notify operations. Clients such as Windows Terminal Server or IIS may require that this number be increased to avoid errors and performance delays.
CAUTION - The approved values for this parameter are 50, 126, 253, and 1124. The most accurate way to determine which number to use is to measure the Redirector-Current Commands statistic on the client with NT perfmon and to increase the number until Current Commands does not hit the negotiated limit. For more information see Microsoft Knowledge Base articles Q191370 and Q232890.
CAUTION - This number should only be changed while cifs is terminated.
CAUTION - Only use the approved values to avoid Q232890.
CAUTION - This value affects allocations in the clients. Use the smallest value necessary for correct behavior.
Default: 50
Values: 50, 126, 253, 1124
Effective: Immediately
Persistence: Remains in effect across system reboots
VFILER CONSIDERATIONS
Each vfiler has its own set of options. Vfilers, however, recognize only a subset of the options recognized by a filer. The list of options recognized by a vfiler are:
  cifs.audit.enable
  cifs.audit.file_access_events.enable
  cifs.audit.logon_events.enable
  cifs.audit.logsize
  cifs.audit.saveas
  cifs.bypass_traverse_checking
  cifs.comment
  cifs.guest_account
  cifs.home_dir_namestyle
  cifs.homedirs_public_for_admin
  cifs.idle_timeout
  cifs.max_mpx
  cifs.netbios_aliases
  cifs.netbios_over_tcp.enable
  cifs.nfs_root_ignore_acl
  cifs.oplocks.enable
  cifs.oplocks.opendelta
  cifs.perm_check_ro_del_ok
  cifs.perm_check_use_gid
  cifs.preserve_unix_security
  cifs.restrict_anonymous.enable
  cifs.save_case
  cifs.scopeid
  cifs.search_domains
  cifs.show_snapshot
  cifs.shutdown_msg_level
  cifs.sidcache.enable
  cifs.sidcache.lifetime
  cifs.snapshot_file_folding.enable
  cifs.symlinks.cycleguard
  cifs.symlinks.enable
  cifs.trace_login
  cifs.universal_nested_groups.enable
  dns.domainname
  dns.enable
  ndmpd.access
  ndmpd.authtype
  ndmpd.connectlog.enabled
  ndmpd.enable
  ndmpd.ignore_ctime.enabled
  ndmpd.password_length
  nfs.mount_rootonly
  nfs.per_client_stats.enable
  nfs.require_valid_mapped_uid
  nfs.tcp.enable
  nfs.udp.xfersize
  nfs.v2.df_2gb_lim
  nfs.v3.enable
  nfs.webnfs.enable
  nfs.webnfs.rootdir
  nfs.webnfs.rootdir.set
  nis.domainname
  nis.enable
  nis.group_update.enable
  nis.group_update_schedule
  nis.servers
  nis.slave.enable
  pcnfsd.enable
  pcnfsd.umask
  rsh.access
  rsh.enable
  security.passwd.rules.enable
  snapmirror.enable
  snapmirror.checkip.enable
  snapmirror.access
  snapvault.access
  snapvault.enable
  wafl.default_nt_user
  wafl.default_unix_user
  wafl.nt_admin_priv_map_to_root
  wafl.wcc_max_entries
  wafl.wcc_minutes_valid
These options only affect the operation of the concerned vfiler. When run in the context of a vfiler, (e.g. via the vfiler run command), the options command only prints the options recognized by a vfiler, and can only change these options.
sjallabais
Thanks!
Now I see from the 8.0.1 Release notes that the default cifs.max_mpx value has changed to 255??
http://now.netapp.com/NOW/knowledge/docs/ontap/rel801/html/ontap/rnote/GUID-134FBB03-7323-474B-A0C5-3399CA43D737.html
How does this compute, are there also new rules for the default values?
How does this relate to vfilers (and vfiler0)?
Lots of questions 🙂
Regards
/Sjalla
