Network and Storage Protocols
Syslog maintenance
shilpa_goel
Where can I find the syslog log file...If it is there what are the settings I have to go through to enable the creation of syslog and what is its format????
4 REPLIES 4
dominicb
Syslog file is at /etc/syslog.conf (cifs share will be \\filername\etc$\syslog.conf)
Have a look at this KB, explains how to setup syslog.
https://kb.netapp.com/support/index?page=content&id=1010374
or do you mean the messages file?
You might want to have a look at /etc/messages if you are after a general record of what the filer has been up to recently.
SACHIN_CHOUDHARY
In our environment ,we are not able to view the latest syslog messages as well  ie : cant view messages ,however can easily view messages.0 nad messages.1 files ..
syedfaisal
try following:
rdfile /vol/vol0/etc/messages
you have to give path to the message file, if multiple vfilers running then replace vol0 with the path to the vfiler root.
dominicb
You are using back slashes: rdfile \etc\messages
You need to use forward slashes: rdfile /etc/messages
