Network and Storage Protocols
Volume id or number
storage_india
Hi Team ,
I am getting below error messages.
Sun Jun 23 20:14:29 JST [filername: Gb_Enet-VI/e0d:warning]: Client X.X.X.X (xid 2246074082) is trying to access an unexported mount (fileid 100, snapid 0, generation 13620405 and flags 0x0 on volume 0x13a8934
I do understand this error messages but i am not sure for which volume the errors are coming.  Its mentioned as --> volume 0x13a8934 .
How to de-crypt this ? How to get volume name from ID or Number in messages file.
Regards
Sandeep..
3 REPLIES 3
paul_wolf
That is the NFS fsid for that volume. I know you can get the FSID of a volume by going into 'priv set advanced' and execute a 'vol read_fsid [volname]' but I'm not sure how to do the reverse.
rsankuru
Hi Sandeep,
You got workaround on this issue??
how you fixed this?
I am also facing same issue even no nfs exports in my filer..
Thanks,
Raviteja
SeanHatfield
In priv set advanced use inodepath:
inodepath -f <fsid> <fileid>
For example, the OP's sample looked like this:
inodepath -f 0x13a8934 100
the output should resemble this:
dot824*> inodepath -f 0x8281167d 100
Inode 100 in volume vol0 (fsid 0x8281167d) has 1 name.
Volume UUID is: 6c4cc9f2-aa8b-4545-b1e2-c04e48788d01
[    1] Primary pathname = /vol/vol0/etc/tape_config/sample
dot824*>
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
