Network and Storage Protocols
cDOT 8.2p4 problems joining AD - (Error: Strong(er) authentication required)
loudymanschwab
Anyone hit this particular error when trying to join cDOT 8.2p4 SVM to AD (SVM and domain names, username, and IPs blanked out)?
Error: CIFS server creation procedure failed
  [  0 ms] Trying to create CIFS server 'XXX' in domain
           'XXX' for virtual server 'XXX'
  [    24] Found 6 domain controllers through DNS
  [    24] Connecting to LDAP (Active Directory) server
           XXX (x.x.x.x) as
           USER
**[    25] FAILURE: 'CifsServer' configuration not available
  [    29] Unable to connect to XXX
           through the x.x.x.x interface (Error: Strong(er)
  [    30] Connecting to LDAP (Active Directory) server
           XXX (x.x.x.x) as
           USER
  [    35] Unable to connect to XXX
  [    35] Connecting to LDAP (Active Directory) server
           XXX (x.x.x.x) as
           USER
  [    43] Unable to connect to XXX
Error: command failed: Failed to create CIFS server XXX. Reason: LDAP Error: Strong authentication is required.
Found a few similar errors about other LDAP clients that said to set these two GPO configs, but this did not help my problem:
    • Domain controller: LDAP server signing requirements = None
    • Network security: LDAP client signing requirements = Negotiate
1 ACCEPTED SOLUTION
loudymanschwab
Found problem to be this GPO being applied to DCs that we had set to required.  cDOT 8.2p4 does not support LDAP signing (nor LDAP SSL).
Computer Configuration\Policies\Windows Settings\Security Settings\Local Policies\Security Options\Domain controller: LDAP server signing requirements
1 REPLY 1
loudymanschwab
