Network and Storage Protocols
frustrating problem with NetApp CIFS Shares and Network Drives
jenoptik
Hi everyone,
After I tried so many things to get a problem solved with netapp-shares & win7 network drive mappings, I decided to post it here.
My Problem is:
Users map their network drives by using a logon-script (lying at the DC) after boot/login and the network drives are marked as not connected (red cross symbol).
The Network drives are mapped using DFS(netapp-vol -> netapp-share -> dfs-path <- mounted by user
I tried:
manipulation of the script to wait for network connection
manipulation of the script to wait just more than 30 seconds
manipulation of the script to kill/remap drives in different ways
manipulation of the registry for waiting of network connection (1 of 6 drives mapped correctly)
manipulation of energy options in the configuration of the NIC
Now, I'm at the end of my knowledge.
May you have any hints what I can do?
Are there existing filer options I have to know for a share/dfs/network drive constellation?
Thx,
jenoptik
1 REPLY 1
Anoop
Hi,
This needs detailed analysis of the scripts to narrow down on the issue. Please check if the shares been configured as per the best practices below
http://www.netapp.com/us/media/tr-3967.pdf
http://www.netapp.com/us/media/tr-3782.pdf
Regards,
Anoop
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
