Network and Storage Protocols
setting nfs3 quota using rpc
MICHAL_GRZEDZICKI
8.1rc1 running 7-mode
client is running linux 3.2 with
Quota utilities version 4.00-pre1.
Compiled with: USE_LDAP_MAIL_LOOKUP EXT2_DIRECT HOSTS_ACCESS ALT_FORMAT RPC RPC_SETQUOTA BSD_BEHAVIOUR
mount options are
rw,sec=sys,noatime,tcp,soft,rsize=32768,wsize=32768,intr,nfsvers=3,usrquota
quota reporting works as expected, (there is a generic quota set for all users)
# quota -u 1296
Disk quotas for user xxx_www (uid 1296):
     Filesystem  blocks   quota   limit   grace   files   quota   limit   grace
netapp-1b:/vol/vol_www1/
                  17444  104857600 104857600             349  4294967295 4294967295
but seting the quota fails
setquota -u 1296 -r 999 9999 999 999 /www_nfs/
setquota: Cannot write quota for 1003 on netapp-1b:/vol/vol_www1/: Connection refused
netapp replys with
Accept State: program can't support procedure (3)
to linux
V1 Procedure: SETQUOTA (3)
rpc call
What can be wrong about our setup ?
1 ACCEPTED SOLUTION
MICHAL_GRZEDZICKI
answering to myself,
this won't work over rpc with netapp,
You can use netapp-managebility api and set quota using a simple script
Michal Grzedzicki
1 REPLY 1
MICHAL_GRZEDZICKI
Michal Grzedzicki
