Network and Storage Protocols
snmp statistics for 'disk-busy'
jasonwu
Hi  There,
Is there anyway to get disk-busy statistics by snmp trap? something like 'disk utilization' by sysstat command .
Thanks and Regards,
Jason
3 REPLIES 3
anthonyfeigl
Hey Jason,
You can determine disk busy by looking at the sysstat in the following manner.
As you can see below my Disk util hit 27%.  If this number is high (like 80%) than your disks (spindles/aggrs) are getting hammered.
That would be when you would want to look at doing a wafl reallocate or to rebuild the aggr.
I am not sure how to SNMP this, but you could write a script to rsh into the filer and pull the stats regularly and email them to you.
ANTHONYS-FILER> sysstat -s -x 1
CPU   NFS  CIFS  HTTP   Total    Net kB/s   Disk kB/s     Tape kB/s Cache Cache  CP   CP Disk    FCP iSCSI   FCP  kB/s
                                  in   out   read  write  read write   age   hit time  ty util                 in   out
  0%     0     0     0       0     8     0    132      0     0     0   >60  100%   0%  -    6%      0     0     0     0
  0%     0     0     0       0     4     0    128      0     0     0   >60   98%   0%  -    2%      0     0     0     0
  1%     0     0     0       0     4     0      4      0     0     0   >60  100%   0%  -    4%      0     0     0     0
  0%     0     0     0       0     5     0    132      0     0     0   >60  100%   0%  -    7%      0     0     0     0
  0%     0     0     0       0     6     0    128      0     0     0   >60  100%   0%  -    6%      0     0     0     0
  1%     0     0     0       0     5     1    744    684     0     0   >60  100%  30%  T   27%      0     0     0     0
  0%     0     0     0       0     4     0    124      0     0     0   >60  100%   0%  -    4%      0     0     0     0
  0%     0     0     0       0     5     0    128      0     0     0   >60  100%   0%  -    4%      0     0     0     0
  0%     0     0     0       0    12     0    132      0     0     0   >60  100%   0%  -    4%      0     0     0     0
  0%     0     0     0       0     9     0    128      0     0     0   >60  100%   0%  -    5%      0     0     0     0
  0%     0     0     0       0    12     0    128      0     0     0   >60  100%   0%  -    5%      0     0     0     0
  0%     0     0     0       0    12     0    124      0     0     0   >60  100%   0%  -    8%      0     0     0     0
  1%     0     0     0       0     6     0    140      0     0     0   >60  100%   0%  -    6%      0     0     0     0
Summary Statistics (   13 samples  1 secs/sample)
Min
  0%     0     0     0       0     4     0      4      0     0     0   >60   98%   0%  *   2%       0     0     0     0
Avg
  0%     0     0     0       0     7     0    167     52     0     0   >60  100%   2%  *   6%       0     0     0     0
Max
  1%     0     0     0       0    12     1    744    684     0     0   >60  100%  30%  *  27%       0     0     0     0
Hope this helps.
Anthony Feigl
brianBOFH
Also, be aware that the disk util% Anthony is referring to above only shows the single most busy disk in the system and should not be used as an authoritative data point.
Capturing a statit during a period of expected load will give you a much better indication of what your disk performance looks like overall.
ensenda_na
After loading the MIB in our SNMP trap server I found that all the items for sysStat.cp.xxxxxxx would trap the disk-busy stats. You have to interpret them though.
IE:
.1.3.6.1.4.1.789.1.2.6.7.0 MIB OID = enterprises.netapp.netapp1.sysStat.cp.cpFromCpOps.0. The count on this = 2559
This would technically be the CP TY that = B for back to back CP's
.1.3.6.1.4.1.789.1.2.6.2.0 MIB OID = enterprises.netapp.netapp1.sysStat.cp.cpFromTimerOps.0. The count for this is 4209037
This CP TY would = T
Search for the OID's that contain sysStat in them and you'll find em.
