ONTAP Discussions
How to accelerate a running snap mirror job.
NairAJ
All,
We have a snap mirror replication which is in progress and has a throttle. I can change the throttle to get this completed sooner but as far as i know the new throttle parameters will come into effect only for new replication. The one running is a first replication which may be at 50% done and it is over WAN.
Is anyway i can accomplist this replication sooner ?
Any suggestion is appreciated.
Thanks.
1 ACCEPTED SOLUTION
JGPSHNTAP
If the relationship is throttled, you need to wait until it completes to take the new effect.
If you set the global flag, options replication  - than you can jus turn that off
I tend to always set global setting, allows for more flexibility
1 REPLY 1
JGPSHNTAP
