ONTAP Discussions
NFS Volume Mount Client Listing cDOT 8.3
Mike_Pedigo
I have used the following procedure to identify what clients are accessing NFS exports in a cDOT cluster.
http://community.netapp.com/t5/Data-ONTAP-Discussions/NFS-Volume-Mount-Client-Listing/td-p/42397
We recently upgraded the client to 8.3.1 and have discovered that this procedure no longer provides which volume the client is accessing, and I can't find any documentation that would provide an alternate method.
Does anybody have any suggestions or know of a way to obtain the volume that a client is accessing via NFS in 8.3+?
Thanks!
Michael Pedigo
1 REPLY 1
juliusblash
This process works for me. You have to collect statistics data first.  I only let it run for a few seconds. You may want to let it run longer depending on the amount of NFS activity you have.
statistics start -object client
statistics stop
statistics show -object client -counter nfs3_ops -fields Instance, Value
