ONTAP Discussions
OSSV snapvault relationships not showing up under external relationships in Protection Manager
KWOCKJ_ADM
I have about 3 dozen Windows servers backing up to filers in our datacenter via OSSV and Protection Manager.  I've come across a couple cases now where everything goes smoothly however the snapvault relationships never show up under external relationships in Protection Manager.  Is there a way to manually import these relationships or a quick fix to get them to show up?  Snapvault update commands work fine so I know the relationship is ok.
1 ACCEPTED SOLUTION
KWOCKJ_ADM
In case anyone else was having the same issue, I was able to resolve it myself.
In Protection Manager, modify the dataset and under Backup add the target volume to Physical resource then add under Primary data, add the OSSV target directory and it should say it will create a backup relationship between the OSSV target directory and the target volume.
5 REPLIES 5
KWOCKJ_ADM
anyone?
KWOCKJ_ADM
RAVI_PALADUGU
Hi Jason,
Glad you were able to fix it. I haven't seen this post and so didn't respond back. It's a good idea to share the possible solution for this issue. Also as part of your PM setup don't forget to enable the alerts, you can actually have a very customized alerts from PM. it's a great product as long as you know how to set that up properly and do the right policies. Also please make sure you mark this answered as people can view into this when they come across this issue.
Best,
Ravi
KWOCKJ_ADM
Strange, I don't see where I can mark it as answered.
RAVI_PALADUGU
It should be under your question or next to any answer. Are you using IE by any chance?? It works on firefox..
