ONTAP Discussions
Reversing snapmirror between C Mode and 7 Mode
ROBIN_YAN_WFHK
I have a volume level snapmirror which source is on 7 Mode and DR is C-Mode (We are in the middle of product upgrade). In this scenario, Just wonder, can I perform snapmirror reversal to change replication from C Mode to 7 Mode? If so, how can I do it?
Source (7 Mode) is FAS6080 and running 8.1.3 and DR (C Mode) is FAS8080 and running 8.3.1.
Thank you!
Ron
1 REPLY 1
SeanHatfield
Transition Data Protection relationships (TDP Snapmirror) are one way only, 7 Mode to C-Mode.  To reverse the flow you need to transition the source of the relationship to Clustered Data ONTAP.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
