ONTAP Discussions
Volume SnapMirror while using volume autosize
jeffburger
I have NetApp volumes that I am SnapMirror'ing that are also autosized if the volume fills up.
It is a manual process to grow the destination volume when the source volume automatically grows in size.
Is there any way to automate this?
So far I found found none.
I was thinking someone had to have come across this before.
1 REPLY 1
radek_kubka
Yep, from what I can tell it is a common annoyance without a neat fix.
What I normally recommend is to make destination volumes way bigger than source & thin provision them (guarantee set to none), regardless of provisioning policy at the source.
Regards,
Radek
