ONTAP Discussions
mutiple routes with same destination and metric
ACHOU_SIMG
ONTAP 9.1RC1 on 6-node cluster
HI,
I just notice on my cluster, an SVM has the following routes:
ntap01::> network route show
Vserver             Destination     Gateway         Metric
vs1
                    0.0.0.0/0       172.25.0.1      20
                    0.0.0.0/0       192.168.87.1    20
The SVM has LIFs on these two subnets (one for data and the other for backup traffic). I am wondering the above routes pose any risks espeicially they both have same metric value. Is it smart enough to know that if the LIF is on 172.25.0.0 subnet, use the 1st route for outgoing traffic and if the LIF is on 192.168.87.0 subnet, use the 2nd route?
Thanks,
1 REPLY 1
Sahana
Hi,
ONTAP uses source-address based routing in which the subnet matching the source is preferred route.
use subnet route of 20.20.20.0/24 to reach
 destination 20.20.20.1.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
