ONTAP Discussions
what are the differences between the ONTAP Edge versions? DOvM100 CBvM100 FDvM100
adamvh
Hello,
Reading through the datasheets and documentation I can't seem to find the differences between the different Data Ontap Edge versions.
DOvM100 ?
CBvM100  Data ONTAP Edge
FDvM100 Data ONTAP Edge-T
This little table did show some differences with regards to the SnapVault, SnapMirror feature.
Does that make Ontap Edge-T the 'premium' edition? If someone could elaborate in more detail would be fantastic.
Thanks
1 REPLY 1
jeffwhit
There are two key products in the Data ONTAP Edge family, there is the base Data ONTAP Edge platform and the Target solution Data ONTAP Edge-T.  they have the same based feature set (capacity, 7-mode, single node, Dedupe, SnapShots, etc.) with a few key differences.  The based Edge platform supportes SnapVault as a primary location only and requires a SnapVault relationship with a back-end FAS system in order for the environment to operate.  Data ONTAP Edge-T can be both a primary SnapVault location as well as a target, supports bi-directional SnapMirror and can operate as a standalone platform.  Edge-T does not require and data protection relatioships for the software to operate.
The DOvM100 is the Data ONTAP-v technology that is only sold by Fujitsu in the VSX960 hardware solution.
