ONTAP Hardware
Aggregate In Place Upgrade to 64-Bit
jasonnash
Hi All,
Just wanted to check the current positon on this. We are running 8.1.2 on a FAS2040. Is it still true that the only supported method of upgrading an aggregate to 64-bit is to add disk to take it beyond 16TB? Is it not possible to add disk but the resulting total size being less than 16TB and still upgrade?
Jason
1 REPLY 1
scottgelb
Yes.  The only supported method is to grow over 16TB.  There have been some posts about the unsupported method if you search but I wouldn't run the diag commands on a production system.
