ONTAP Hardware
Cisco switch for FAS2520 and SPARC T5 (10GBASE-T)?
SeanODell
Hi All,
I have a dual controller FAS2520 with built-in disk shelf.
The FAS2520 has 10Gb 10GBASE-T interfaces (no fiber).
I also have a SPARC T5 with 10GBASE-T nics.
I am trying to find a Cisco switch to connect the FAS2510 and the SPARC T5.
Any recomemdnations?
All input is welcome, especially from those that have similar configuration up and running.
Regards,
Sean
1 REPLY 1
Piererscotland
I used the 3750X with the 2 x 10GbaseT module.  Seemed to be the only reasonably priced Cisco with 10GbaseT....
