ONTAP Hardware
DS4243 and V-Series
cschnidr
It seems that the new shelf DS4243 will be supported on V-Series.
Is it supported on single as well as on clustered systems? Also is it supported on V-Series Fabric Metrocluster (non-mirrored)?
Thanks
Christoph
1 ACCEPTED SOLUTION
isaacs
Hi Chris,
Yes, single and clustered heads are supported. Metrocluster with Native disks is not supported.
Thanks!
2 REPLIES 2
isaacs
Hi Chris,
Thanks!
sshapiro
Dan's answer is of course correct, although the appropriate terminology for an dual-controller system is an HA pair or HA system; cluster is the term for multi-node GX or Data ONTAP 8 clustered systems.
The reason the DS4243 shelf cannot be used in either stretch or fabric MetroCluster configurations has to do with SAS specification limits on cable lengths: the current maximum supported passive SAS cable is 5m. SAS use copper cables; there is no physical interface for fibre and switches.
Skip Shapiro
