ONTAP Hardware
Disk Replacement
MJABER
Dear all ,
i am new to netapp community and i have queastion regarding disk replement , i got one disk failed and i need to replace , both disk are the same specification but the new one doesnt have any sticker as the old one from Netapp .
is this could be an issue ?
i have also tried to replace the disk and still show the amber light?
Thanks
9 REPLIES 9
xavierpitz
Hello,
How can you be sure that the specs from the "new" disk are the same if the label is missing ?
Can you have a look at a "aggr status -f" output and the "rdfile /etc/messages" output during the time you removed the old disk and replaced it with the new one ?
Xavier
MJABER
xavierpitz
Do you still see any failed disk when you look at the :
"aggr status -f"
output ?
Do you see the "new" disk as new spare with :
"aggr status -s"
MJABER
i have attched the two disk picture
the one with no lables is the new one which is not working or giving the amber light
ONLY150_321
Hi,
your spare disk is not a Netapp spare part. You can see it at the FW. Netapp FW is NA02 (NAxx).
MJABER
hi ,
thanks for your reply , so if i did disk firmware will solve the issue ?
ONLY150_321
the system cannot work with this disk, normally it´s not possible to add Netapp FW on a disk with other FW
ismopuuronen
Hi,
In CDOT it could be that the new disk is unowned and thats why the led is abmer after replacement.
CLI:
> system node run * disk show -n
> system node run * vol status -f
Br,
Ismo
MJABER
i have attached the picture of two disk i have
the one with no lables is the new one which is not working when replaced
any advice ,,,
