ONTAP Hardware
FAS 2552 Power Supply
nachito
Good day All.
Does anyone know if the Power Supplies in FAS2552 are autosensing, that means can I plug them into 100 or 220 v?
Is there a Paper that explains it?
Thanks a lot.
1 ACCEPTED SOLUTION
scottgelb
Yes. 100-120 and 200-240.  hwu.netapp.com has info on all platforms...great resource for specifications and everything supported on each platform.
2 REPLIES 2
scottgelb
aborzenkov
It is not very obvious, at least mobile version. It never really says there is single power supply for both cases. Actually, it lists two FRU numbers for PSU without much info what the difference is.
