ONTAP Hardware
FAS2020:Luns not visible after takeover
shashidhargc
Hi,
Ther's FAS 2020, ith controller1 sharing a few LUNs to a Windows machine. Controller2 is standby. Recently there was Controller replacement on Controller2. After the replacement
when cntrllr2 takes over cntrllr1, luns are not visible.
CNTRL01> fcadmin config
                  Local
Adapter Type      State                  Status
  0a   target     CONFIGURED             online
  0b   initiator  CONFIGURED.            online
CNTRL02> fcadmin config
                  Local
  0a   initiator  CONFIGURED             online
  0b   target     CONFIGURED             online
Need help, kindly let me know wat settings can i check to troubleshoot this issue.
1 ACCEPTED SOLUTION
shashidhargc
Problem was solved after updating the WWPNs of new controller on to the SAN switch zones.
Guess the FE who replaced the controller forgot to do it.
2 REPLIES 2
rickymartin
Sounds a little like the change in the serial number of the new controller has changed the serial number of the LUN's (depends on how the upgrade was done see https://kb.netapp.com/support/index?page=content&id=1011538), or possibly that the WWNN or WWPN info has changed and the mapping back to the hosts via the SAN isnt right any more.
If you havent already done so, raise a P1 case with NetApp support.
shashidhargc
