ONTAP Hardware
FAS2220/HA - fail to configure/use partner interface
DMOROZOVSKY
Dear colleagues,
I'm trying to configure our 2220/HA to be actually HA
/etc/rc configs are like
#Auto-generated by setup Sun Dec  2 12:59:22 MSK 2012
# modified by marck 20130513 2115
hostname fas2220a
ifgrp create lacp la0a -b ip e0a e0b e0c e0d
ifconfig la0a `hostname`-la0a mediatype auto partner la0b mtusize 9000
ifconfig la0a alias `hostname`-1
ifconfig e0M `hostname`-e0M partner fas2220b-e0M mtusize 1500
route add 192.168.192.0/24 192.168.136.254 1
routed on
options dns.domainname xxx.domain.tld
options dns.enable on
options nis.enable off
savecore
(and similar for 2220b)
However, after manual cf takeover I do not see neither partner's IPs up nor aggregates/volumes.
ifconfig la0a still reports
fas2220a(takeover)> ifconfig la0a
la0a: flags=0x22fcc863<UP,BROADCAST,RUNNING,MULTICAST,PARTNER_UP,TCPCKSUM> mtu 9000 dad_attempts 2
    inet 192.168.136.220 netmask 0xffffff00 broadcast 192.168.36.255
    inet 192.168.136.221 netmask 0xffffff00 broadcast 192.168.36.255
    inet6 fe80::a0:98ff:fe31:f1fc prefixlen 64 scopeid 0xa autoconf
    partner la0b (not in use)
    ether 02:a0:98:31:f1:fc (Enabled interface groups)
Quick googling does not help; what simple did I miss?
Thanks in advance.
2 REPLIES 2
billshaffer
ifconfig _should_ look the same after a takeover - that tells you that the network config came across okay.  You say you don't see either partner's IP - via ping, ifconfig, or what?  You also say you don't see the partner aggregates/volumes - again, how?  aggr/vol status, or trying to mount/map, or ...?
Are the IPs you posted for la0a correct?
Please post both /etc/rc, and both /etc/hosts.
Bill
DMOROZOVSKY
Actually, I don't exactly know what did I missed, possibly some /etc/hosts records, but right after my post next experiment shown correct failover,
and ifconfig reported:
la0a: flags=0x22fec863<UP,BROADCAST,RUNNING,MULTICAST,MULTIHOST,PARTNER_UP,TCPCKSUM> mtu 9000 dad_attempts 2
        inet 192.168.136.220 netmask 0xffffff00 broadcast 192.168.136.255
        inet 192.168.136.221 netmask 0xffffff00 broadcast 192.168.136.255
        partner inet 192.168.136.222 (la0b)
Test iSCSI target does handed over correctly both in auto takeover and in manual giveback.
Thank you.
