ONTAP Hardware
FAS2240-4 with 12x2TB and a default storage configuration?
I_GOLOVIN_KELWAY
I am trying to design the storage configuration for this box with two additional DS4243 with 450GB SAS disks. What is the default aggregate configuration which will be shipped from factory? I would imagine it will be an aggr0 on 3x2TB  with root volume in it for each controller?
5 REPLIES 5
aborzenkov
Yes.
I_GOLOVIN_KELWAY
Thanks for this. Do you also know in what slots those 12x 2TB drives will be installed by default?
radek_kubka
Does it make any difference for you? If it does, you can swap theme around (when the filer is powered off).
Regards,
Radek
I_GOLOVIN_KELWAY
It is kinda a weird answer really. I recon you dont know?
I am doing a proper LLD and you would normally need to put a disk placement in there, hence the question. If you reshuffle the disks after you would need to reconfigure the aggregates including the one with a root vol?
radek_kubka
I don't know, indeed, as I never considered this to be important (I'm not even sure whether there is any rule).
Physical location of a disk in a particular bay is irrelevant - you can actually move an entire aggregate to a different system (re-ordering disks at the same time).
