ONTAP Hardware
FAS3220 Question - orange light - warning
dormelchen
hello,
we are running now an FAS3220 in ClusterMode - with 2 shelfs.
Now - we see this orange warning in front of the netapp and at every head.
But we did not find any "errors" in logs etc.
Any ideas where we can find information why this orange light is on ?
We are new in clustered ontap
thanks
4 REPLIES 4
GRAEMEOGDEN
Strange.. I have a very similar problem.
FAS 3220 with 2-node Cluster running ONTAP 8.1.2P3
One node displays an amber light on the controller but running "environment sensors show" everything is normal. No disks or shelves have warning lights.
VOJTECH_TAUCHMAN
Under rare circumstances, the FRU Fault LED may not be cleared and either flash or remain solid.
https://kb.netapp.com/support/index?page=content&id=2016199&pmv=print&impressions=false&viewlocale=en_US
I think this could help you resolve the issue.
ASHWINPAWARTESL
Jus to add to what VOJTECH_TAUCHMAN mentioned, there is a BUG (ID 472202) associated with this symptom.
http://support.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=472202
dormelchen
hello,
fixed it - so waiting for an update
thank you.
