ONTAP Hardware
FAS6030 10GbE Options
SWIEDUWILT
I recently upgraded my FAS6030 to DataOnTap 7.3.7P1 and I am getting an error
Chelsio N310E 10G NIC card (PN X1106A) in slot 8 is not supported on model FAS6030.
I need to upgrade to DataOnTap 8.1 but the TOE Card I have installed in not supported in DoT 8 or higher so what options do I have?
1 ACCEPTED SOLUTION
DOMINIC_WYSS
http://hwu.netapp.com/Adapter/Index
search by model an OS. max Ontap on FAS6030 is 8.1.4
compatible 10GbE NICs:
X1107A     2p 10GbE NIC Op
X1008A     2p 10GbE TOE Op
X1139A     2p 10Gb UTA Op
X1140A     2p 10Gb UTA Cu
X1005A     1p 10GbE TOE Op
3 REPLIES 3
SWIEDUWILT
is there a compatibility list available online?
netapp matrix showing Data on Tap versions and what options are not supported?
throw me a bone here, need to get an order in before the fiscal year budget cycle starts..
DOMINIC_WYSS
SWIEDUWILT
Thank you so much for the Link,
