ONTAP Hardware
Fas 2040 ISCSI start/license problem
benogambo
Hi,
Got brand new Fas2040 and License shows that ISCSI is enabled. When I try to start ISCSI START got iscsi: service is not licensed. Entering license got License add: "iscsi" is included and no license code is necessary.
I'm a little bit confused. Any help?
thanks
Benjamin
1 ACCEPTED SOLUTION
benogambo
With support representative we found a solution:
you cannot manage embedded licenses from cli. using system manager I was able to enable iscsi.
4 REPLIES 4
benogambo
aborzenkov
Really? "options licensed_features"
benogambo
Tried License add and License delete but no dice.
License command shows ISCSI enabled, system manager shows disabled. Once enabled in system manager I was able to start ISCSI.
Didn't try with Options licensed_features....
OPHELIA_GENTRY
It's a year later, but I've just encountered this issue myself and tried the CLI options. For the sake of accuracy to the above 'answer', I'm adding my conclusion here.
aborzenkov is correct. You can enable the licensed_feature option, and it will resolve your iSCSI issue without having to resort to System Manager.
> options license
licensed_feature.disk_sanitization.enable off
licensed_feature.fcp.enable off
licensed_feature.flexcache_nfs.enable off
licensed_feature.iscsi.enable off
licensed_feature.multistore.enable off
licensed_feature.vld.enable off
> options licensed_feature.iscsi.enable on
Run 'iscsi start' to start the iSCSI service.
Also run 'lun setup' if necessary to configure LUNs.
> iscsi start
iSCSI service started
