ONTAP Hardware
Fas3140 Sketched metro cluster upgrade to Fas8000 series
ousturali
hi eveyone ,
we have a job to upgrade the metrocluster heads, it is a big production system .I had previously changed some controllers but not had done a conttroller upgrade.
i had found an netapp article (https://kb.netapp.com/support/index?page=content&id=1011440&locale=en_US) ,but could not completeley understood it.
Does anybody has experience with this ??
or any ideas..
Regards.
1 REPLY 1
georgevj
The KB looks old.
Here is another Document that may help you.
https://library.netapp.com/ecm/ecm_get_file/ECMP1151387
search for "metrocluster" within the doc.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Cannot find the answer you need? No need to open a support case - just CHAT and we’ll handle it for you.
