ONTAP Hardware
Flash Cache not supported in the FAS/V3210 with 8.1?
bjacobsen
Just came across mention that Flash Cache is not supported with the 3210 and 8.1 (footnote 4):
http://www.netapp.com/us/products/storage-systems/flash-cache/flash-cache-tech-specs.html
Has anyone heard why that is? This is very concerning as it seems to suggest that 8.0.2 is the end of the road for us if we wish to continue use of our Flash Cache. I'm finding it hard to believe that this is the case on a system that's only been out for a year and in a system in which Flash Cache was strongly encouraged.
1 ACCEPTED SOLUTION
Jeff_Yao
this is due to burt.
3140 and 3210 with Flash Cache data service outages due to low memory condition.
http://now.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=528631
hopefully helps
3 REPLIES 3
scottgelb
Both 3140 and 3210. Systems with 4gb ram. There is a bug and 8.1 wont recognize the card in these systems. Hopefully 8.1ga or 8.1.1 has a fix. We are using 3240 whenever possible.
Jeff_Yao
hopefully helps
angel_frias
Anyone knows how to monitor for this "Low memory condition"?
