ONTAP Hardware
Help moving shelves from 3020 to 3050c
Idealshopping
HI,
I am looking for some suggestions on what to do when moving 3 shelves form an old 3020 filer to a 3050c.
The 3020 has 3 shelves (ESH2) that i want to move to the 3050c running 7.3.2
Any suggestions and recommendations...
I have already removed all user volumes in the aggr but the root vol (vol0) remains.
Cheers
1 ACCEPTED SOLUTION
aborzenkov
Should be no problem. Old root aggregate will be detected as foreign and remain offline, you simply destroy it. This assumes you do it online, while target file is running.
3 REPLIES 3
aborzenkov
Idealshopping
Thanks for that. Its what I thought but just wanted to make sure I didnt miss something. Looks like thats my monday morning sorted then...
Thanks
Idealshopping
Just as an update, all 3 shelves added without issue. Aggregate added as foreign offline and destroyed. new aggregate currently initializing.
Thanks
