ONTAP Hardware
How many HBA Ports do I need to make a loop, I have a FAS3140 Active/Active and shelves DS14mk4 FC???
jesuscruzj
4 REPLIES 4
aborzenkov
Technically it will work with a single initiator port in every head; but it is highly recommended to have two ports in every head for MP-HA (MultiPath-HighAvailability) cabling. If this is a new system, it should be already configured and delivered with MP-HA from factory.
radek_kubka
Hi,
You actually request this when ordering, so a new system can be shipped either with or without MP-HA cabling.
So for a single loop it will be:
- 1 port per controller for non-MP-HA cabling
- 2 ports per controller for MP-HA cabling
Regards,
Radek
aborzenkov
IIRC for a couple of months only MP-HA systems can be ordered
radek_kubka
Yep, fair enough - there has been a change to quoting tool which I previously missed: MP-HA box now cannot be un-ticked when building 3000 series system; interestingly enough the MP-HA option isn't forced on 2000 boxes (although comment remains the same that MP-HA is required for A/A systems).
Thanks,
Radek
