ONTAP Hardware
How to convert a SPARE disk as DATA disk??
NAYABRASOOL
Hi all,
We have two spare disks out of which one we need to make as data disk can anybody help me out with command to do this. Will the "aggr add" will do please confirm.
Thanks
Nayab
1 ACCEPTED SOLUTION
aborzenkov
Yes, “aggr add” will do exactly that.
4 REPLIES 4
aborzenkov
GARDINEC_EBRD
Be careful - adding one disk at a time to an aggregate is not a great idea if performance is of concern!!
mark_zhang
Hi,
aggr add can work.
I was confused on the situation you met. I have 2 spare disks in the pool. But my aggr need more data space.
I run aggr add and got warning. I quit!!!
aggr add aggr1 -d 0a.26 0a.42
WARNING! Continuing with aggr add will result in a
low spares disk condition for one or more RAID groups.
Are you sure you want to continue with aggr add? n
I think it need spare disks in the pool. So how many spare disks it need? I have 2 Disk shelf, so I think maybe 2 spares.
At last, I tried add one disk, it succeed.
Addition of 1 disk to the aggregate has completed.
So I think it is better left one spare for pool.
cedric_renauld
sure !
You NEED a mimnimum of ONE spare disk by pool
it's mandatory
