ONTAP Hardware
I need some clarification on additional FC cards for a FAS3240
biescas
Hi,
Can you please help with the below request from one of our Partners?
"I need some clarification on additional FC cards for a FAS3240.
I know that the onboard FC ports can be used as either a Target or as an Initiator. If I purchase additional 2 Port or 4 Port FC cards am I right in saying that these cards will only have Target functionality?
Is it possible to purchase additional FC Initiator Cards?"
Thanks,
2 REPLIES 2
aborzenkov
Yes, there are add-on FC imitator cards, e.g. X2054A-R6. It all is described in system configuration guides on NOW.
thomas_glodde
Hi Biescas,
the onboard ports are configurable, they can be either initiator or target.
The addon cards for a FAS3240 are fixed, either 4 port 4gbit initiator, 4 port 4gbit target or 2 port 8gbit target.
check with your local sales representative for the correct cards, numbers and if they fit into your system.
Regards,
Thomas
