ONTAP Hardware
IOPS for SATA/SAS/FC disks
JoeShmoe99
Can anyone tell me what's NetApps stated performance of IOPS on SATA/SAS and FC disks?
After a general idea as realise any answer can be driven by different factors (i.e head type, aggregate setup, application type etc)
7 REPLIES 7
mkopenski
I don't know the stated values. From my experience
sata 70-80 iops
scsi
10k FC/sas  110-120 iops
15k FC/sas 150-160 iops
highvailsys
From my experience with Netapp tech support, the older SATA drives would experience a "diminished state of return" above 40 IOPS.  This was a couple of years ago so it might be different now.
FC/SATA 150-300.
Cheers,
Chris
gyorgy_gattyan
Hi,
I have some rule of thumbs IOPS numbers for SATA and FC disks:
SATA     7200rpm          80 IOPS/sec
FC         15k rpm          180 IOPS/sec
Cheers:
-Gyuri
BrendonHiggins
It is all smoke and mirrors...
Have a read of this blog post to see what is happening on the backend.
Hope it helps
Bren
JoeShmoe99
I cant see the blog URL?
duncan_cosgrave
Hi Brendon
Have you got the link you referenced here?  We're really struggling with our iops atm (as I'm sure you already know!), so anything that might help out is welcome.
Cheers
Duncan
lwei
The number of IOPS will be dependant on the required latencies, regardless of disk types. That said, the chart above gives good estimate.
Thanks,
Wei
