ONTAP Hardware
Installing X1107A in a 3140
smokey007uk
Hi all
Have to install X1107A card into a 3140. I looked  for any install procedure on the netapp website, could  someone could point me in the right direction. If they know of any documentation I could look at
Can't seem to find any guide for installing ethernet cards in fas devices
Cheers for any info
:0)
1 ACCEPTED SOLUTION
AGUMADAVALLI
use the following link and place the card correctly.
it should be ok if you the link (https://hwu.netapp.com/Controller/Index)
thank you
AK G
2 REPLIES 2
AGUMADAVALLI
thank you
AK G
smokey007uk
Thank you very much for that link
Has helped me a lot
:0)
