ONTAP Hardware
NVRAM Size for FAS32xx
mikidutzaa
Hello,
I didn't find the NVRAM specs for each new array type, does anyone know it?
2 REPLIES 2
vmsjaak13
Total NVRAM Active/Active:
FAS3210: 1GB
FAS3240: 2GB
FAS3270: 4GB
Regards,
Niek
scottgelb
Note that these are cluster numbers, so half that for a per node nvram size, and these systems use NVMEM which shares system ram.
