ONTAP Hardware
PANIC: The 0 is not a supported platform, cpu_reset called on cpu#0
aaronswtelogis
Hello
Inherited a FAS3210. Seeing the following:
Phoenix TrustedCore(tm) Server
Copyright 1985-2006 Phoenix Technologies Ltd.
All Rights Reserved
BIOS version: 5.1.1
Portions Copyright (c) 2007-2011 NetApp, Inc. All Rights Reserved
CPU = 1 Processors Detected, Cores per Processor = 2
Intel(R) Xeon(R) CPU E5220 @ 2.33GHz
Testing RAM
512MB RAM tested
5120MB RAM installed
6144 KB L2 Cache
System BIOS shadowed
USB 2.0: MICRON eUSB DISK
BIOS is scanning PCI Option ROMs, this will take few seconds...
Boot Loader version 3.2
Copyright (C) 2000-2003 Broadcom Corporation.
Portions Copyright (C) 2002-2008 NetApp
CPU Type: Intel(R) Xeon(R) CPU E5220 @ 2.33GHz
Starting AUTOBOOT press Ctrl-C to abort...
Loading X86_64/freebsd/image1/kernel:0x100000/3401320 0x53f000/3229520 0x853750/1227824 Entry at 0x80148a80
Loading X86_64/freebsd/image1/platform.ko:0x980000/569180 0xab4480/535320 0xa0af60/17256 0xb36f98/29808 0xa0f2c8/1360 0xb3e408/4080 0xa0f818/54268 0xa1cc18/71003 0xa2e178/1504 0xb3f3f8/4512 0xa2e758/256 0xb40598/768 0xa2e858/968 0xb40898/2904 0xa2ec20/112 0xb413f0/336 0xa2eca0/137088 0xb41540/142200 0xa50420/425 0xa75c60/8377 0xab4392/237 0xa77d20/126120 0xa969c8/121290
NetApp Data ONTAP 8.0.2P4 7-Mode
version: NetApp Release 8.0.2P4: Tue Nov 15 16:16:47 PST 2011
cpuid = 0
Uptime: 1s
The operating system has halted.
Please press any key to reboot.
System halting...
Any idea for direction? I want to reseat the RAM. All shelves are unplugged from controllers, still get the same error.
thanks
1 ACCEPTED SOLUTION
aaronswtelogis
greetings!
I reseated all DIMMs in either controller, the error is gone.
thank you for the reply, this is solved.
hope to get a reply as well on cabling issue. same chassis, trying to figure out what the cabling should be fits the circle->square priciple.
thanks again
4 REPLIES 4
ritusangha
If filer is on LOADER prompt, what does "printenv" show you?
You should see Model or other information.  ( I bet its not there)
You should open a P1 Support case.
 It might be a hardware failure/ bug.
aaronswtelogis
greetings!
thanks again
econde
Hola, tengo el mismo problema. Crees que sea físico e tema? qué debo hacer con los DIMMs?
Hice netboot según estos pasos: https://library.netapp.com/ecmdocs/ECMP1636018/html/GUID-A8CC3DD0-D5DF-424A-84E9-830A5CD00430.html
pero al intentar reiniciar por completo el data ontap o al intentar ingresar en modo de mantenimiento, sigo con estos mensajes:
Please choose one of the following:
(1) Normal Boot.
(2) Boot without /etc/rc.
(3) Change password.
(4) Clean configuration and initialize all disks.
(5) Maintenance mode boot.
(6) Update flash from backup config.
(7) Install new software first.
(8) Reboot node.
Selection (1-8)? 5
Chelsio T3 RDMA Driver - version 0.1
Ipspace "iwarp-ipspace" created
Fri Dec 1 17:20:18 GMT [fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 4a.
Fri Dec 1 17:20:18 GMT [fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 4b.
Fri Dec 1 17:20:18 GMT [fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 4c.
Fri Dec 1 17:20:18 GMT [fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 4d.
Fri Dec 1 17:20:18 GMT [fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 0d.
Fri Dec 1 17:20:18 GMT [fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 0c.
Fri Dec 1 17:20:19 GMT [netif.linkDown:info]: Ethernet Wrench Port: Link down, check cable.
Fri Dec 1 17:20:23 GMT [diskown.isEnabled:info]: software ownership has been enabled for this system
PANIC: sanown: not enough filer table entries
version: NetApp Release 8.0.5: Sun Jan 20 21:53:54 PST 2013
cpuid = 0
Uptime: 50s
PANIC: sanown: not enough filer table entries in SK process sanown_io on release NetApp Release 8.0.5 on Fri Dec 1 17:20:24 GMT 2017
compile flags: amd64, x86_64
Writing panic info to HA mailbox disks.
DUMPCORE: START
Raid assimilation incomplete
DUMPCORE: END -- coredump *NOT* written.
Dumpcore failed
coredump: primary dumper failed -1.
coredump: trying secondary dumper...
no tftp server ip specified
netdump: no targets available to dump
coredump: secondary dumper failed -1.
Logging shutdown event to the SP...
System halting...
All Rights Reserved
BIOS version: 5.3.0
Portions Copyright (c) 2007-2014 NetApp, Inc. All Rights Reserved
CPU = 1 Processors Detected, Cores per Processor = 4
@Intel(R) Xeon(R) CPU L5410 @ 2.33GHz
Testing RAM
512MB RAM tested
8192MB RAM installed
6144 KB L2 Cache
BIOS is scanning PCI Option ROMs, this may take a few seconds...
Boot Loader version 3.6
Portions Copyright (C) 2002-2014 NetApp, Inc. All Rights Reserved.
@CPU Type: Intel(R) Xeon(R) CPU L5410 @ 2.33GHz
LOADER-A>
@aaronswtelogis wrote:
greetings!
thanks again
AlexDawson
Hola econde,
Lo sentimos, su problema no son los módulos DIMM, es debido a que el nombre del sistema cambia dos veces sin reiniciar - https://mysupport.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=782865 . Intente ingresar al modo de mantenimiento sin los discos encendidos, luego encienda los discos y ejecute "disk show -an".
Si tiene un contrato de soporte, puede llamarnos para obtener ayuda en español - https://www.netapp.com/es/services-support/ngs-contacts.aspx
Sorry, your problem is not the DIMMs - it is (usually) due to the system name changing twice without a reboot.
Attempt to enter maintenance mode without the disks powered on, then turn on the disks, and run "disk show -an"
If you have a support contract, you may call us for help in Spanish - https://www.netapp.com/es/services-support/ngs-contacts.aspx
