ONTAP Hardware
Partner not correctly configured, needs to be erased.
SVIZIKIDIS
Hi,
first of all let me say that i am a newbie in Netapp systems.
I have a FAS2020 with two controllers.
I have done the initial configuration on both controllers, downloaded SystemManager and trying to configure the system.
The problem is that when i am trying to add one of the two controllers and after putting in the IP i get a message that i need to fill in the partner ip. Whatever i put i get an error saying that cannot find the partner.
I tried through CLI giving ifconfig e0a -partner which gives ifconfig: partner not found.
How can i disable the partner which i don't intend to use?
Thanks
1 REPLY 1
rwelshman
Just to clarify:
You're already gone through the basic install portion and given both of the filers IPs?
Can you log into both of them individually through SSH?
