ONTAP Hardware
Problems with joining a new cluster
DIAMETRICH
Hello,
I am completely new to NetApp. I've just set up two FAS3050c's with 4 DS14mk2 disk shelves attached via FC-AL. The nodes are running OnTAP GX 10.0.1P2. In the process of configuring the nodes, I created a cluster on one node, then attempted to join it on the second node. I'm getting the following message repeating on the second node, after the 'cluster join' command:
Cluster join waiting: Waiting for local Replication Database (RDB) to become ready
The first node ('toast1a') shows the second node ('toast1b') in the right places:
toast1a::> system show
Node      Health Eligibility Uptime        Model       Owner    Location
toast1a   true   true        03:08         FAS3050
toast1b   false  true        -             -           -        -
But it also says, under things like 'cluster statistics show', that the replication service is offline (this sounds relevant to me):
toast1a::> clust statistics show
      Counter         Value         Delta
    CPU Busy:            3%             -
   Operations:
       Total:             0             -
         NFS:             0             -
        CIFS:             0             -
Data Network:
        Busy:            0%             -
    Received:        1.91MB             -
        Sent:            0B             -
Cluster Network:
        Busy:            0%             -
    Received:         116MB             -
        Sent:        1.61GB             -
Storage Disk:
        Read:         375MB             -
       Write:        6.02GB             -
WARNING: Unable to list entries for mgwd on node toast1b. mgwd on node toast1b is currently not accepting administrative requests. Replication service is
         offline.
Question: How do I get the replication service online? This seems to be required for joining the cluster. Please let me know if additional information is required; I'm not sure what all is relevant here. Thank you!
1 ACCEPTED SOLUTION
DIAMETRICH
I rebooted the second node after waiting on it for a couple hours. Now it appears to be a cluster member with no problems ... ahh, magic. Just what I want in my systems.
1 REPLY 1
DIAMETRICH
