ONTAP Hardware
SNMP
NAYABRASOOL
Hi All,
Can any body plzz guide me how to configure the SNMP on my filer as we had a power supply failure in the morning and haven't received any alert for that,thanks for the redundant power supply which saved us from downtime.
Please help me from all the basic steps as i am a fresher.
Thanks
Nayab
2 REPLIES 2
kvinay
Please use the following command on your filer to configure SNMP , also just type snmp on the command line to see the current status of it
snmp options
Options are:
                   (no option => display current settings)
        authtrap   [ 0|1 ]       (0 => disabled, 1 => enabled)
        community  [ add ro <community> ]
        community  [ delete { all | ro <community> } ]
        contact    [ <contact> ]
        init       [ 1 ]         (0 => uninitialized, 1 => initialized)
        location   [ <location> ]
        traphost   [ add|delete <hostname|ipaddress> ]
        traps      [ enable|disable|reset|delete ] [ <trapname> ]
        traps      <trapname>.<parm> <value>
        traps      walk <prefix>
        traps      load <filename>
Regards,
Vinay
BABJISHAIK
Hi Nayab
This is Shaik plz give ur mail ID I will post u later
