ONTAP Hardware
Swap a disk between filers?
mark_flint
So, I need to swap disks from an older out of maint filer, onto a newer out of maint filer....I *think* I should just unown spare disks, and then
own them on the new filer, as they're both the same physically, and both systems are on 8.1 releases. Am I right? or am I about to get it all
horribly wrong.....
`Mark
3 REPLIES 3
paulstringfellow
Sounds OK in theory….
Never done it though.
Just need to make sure the firmware revisions are in your disk file for the new controllers you are moving to…and in theory should be OK.
Maybe worth a NetApp support question though ,just in caese.
mark_flint
It worked 'as advertised'   As long as the disk is ok, and you unown it, it works
just like a normal disk replacement.
`Mark
paulstringfellow
Good stuff…
